Old 02-26-2013, 10:27 PM   #20 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Good job on the mold metrompg. Every time you make something custom like this you will learn better how to do it.
Jamesqf: I thought only Ford did that, putting a "gauge" then hooking it to a switch. The temperature gauges on many Ford cars are just a glorified idiot light.
Originally Posted by jamesqf View Post
If you're driving an Insight, the temp gauge isn't even a glorified idiot light. Mine jumps to 5 bars at ~145F, and stays there even at 230F (per Scangauge).
Also, I don't see any temps much above normal on level ground, at any speed. It's only climbing that apparently produces more heat than the radiator was designed to handle.
Noah Webster, 1787
