Old 02-27-2013, 11:04 AM   #102 (permalink)
oil pan 4
My AMP20 starting battery has been tested.
With my construction methoid using 8mm brass hardware to secure tabs together and secure lug connectors to tabs using 4 lengths of 8ga wire on the grounds and 2 lenghts of 6ga meeting up with 00 gauge power leads. With a 350amp anderson forklift QD has resulted in a battery that can put out at least as many cranking amps a brand new fully charged 44lb optima battery, which is some where around 1200 amps.
