02-27-2013, 02:41 PM
#14 (permalink)
Originally Posted by Frank Lee
OOOOOOOOOOOOOOOOOOOOoooooooooooooooh, a Sable! Why didn't you say so? I had the plastic water pump impeller disintegrate on mine; caused overheating, percolating sounds from the heater, and coolant loss with NO cooling system leaks. Check water pump output and if none REPLACE!
http://ecomodder.com/forum/165952-post11.html
Okay. How do I do that?
