Old 02-27-2013, 07:08 PM   #1037 (permalink)
Davinator61
Originally Posted by mosier View Post
dcb:
What method did you use to calculate your microseconds per gallon?
For a DOHC Saturn, with 21lb/hr injectors I get
Code:
21.00       lbs/hr
6.25        lbs/gal gas  (~72 deg F gas)
3.36        gal/hr
17.86       minutes/gal
1,071.43    seconds/gal
1,071,428,571.43	microseconds/gal  per injector
267,857,142.86          microseconds/gal with 4 injectors?
Fuel temperature will have a big impact on the calculation, I wonder how scanguage or oem systems handle this (ignore it?).
I just put in my order, and hope to get it running on my non-obdii SL1 pretty soon..
I tried your by-hand formula versus the Excel Spreadsheet calculator posted on the Ecomodder.com Wiki, as applied to my 1991 Jeep Cherokee Laredo 4.0L Inline-Six engine, and found two different numbers as a result, with a variation of 7,894,737 between the 197,368,421 as done by hand, versus 189,473,684 as calculated by the Excel Spreadsheet calculator.
My advice, in this case, would be to try each of both numbers, first the low, then the high, then adjust incrementally by around 5-10% of the difference (193,421,053, in my vehicle's case) until you find the actual "Sweet-Spot" for accurate fuel consumption numbers. I have found my MPG numbers are POSSIBLY off by as much as 10-15% or MORE when just using the Excel Spreadsheet calculator's number, otherwise. Hope this helps, even if only a little...
Edit: Just tested out my theory, based on the two calculations and found that also dropping BELOW the lower calculated Microseconds-per-Gallon by the calculated difference between both numbers MAY also have a positive effect on accuracy of the Microseconds-per-Gallon equation. More testing AND re-calibration of the MPGuino will be necessary in order to confirm this, of course.
