Pull the cover off if you can see the ribs from the back it's time. When In doubt change it. It's cheaper than replacing the head. The valve cover comes off you use feeler gauges and measure the lash it's like an old school v8 there is a nut and a screw. You need to download the FSM from Honda Hookups. It'll tell you how to do any and everything to the car.
