Old 02-28-2013, 03:59 AM   #3 (permalink)
Arragonis
The PRC.
The Camry is 10cm longer and 3cm wider than the Octavia we had before. The new Octavia is pretty much the same size as the Camry, and there is a new model - The Rapid - in between the Octavia and smaller Fabia.
I'm cautious about going with another Skoda as the dealer turned out to be totally useless. VW equivalents are more spendy but you end up with less stuff too.
It may even end up we have another Toyota - they do reasonably good Diesels here - but only if we can be sure it doesn't rattle, and definitely not a Prius again. The Auris Hybrid is too small.
Not sure, we will ponder the options next June.
