Old 02-28-2013, 11:27 AM   #68 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Using your same chassis you might consider building a structure similar to light aircraft using a tubular frame work and covering it with heavy dacron fabric.
I have seen a trailer made using a coroplast skin over a metal frame. A friend made a fairly good shaped box that fit on a flat bed trailer he covered it with aluminum panels from semi truck trailers but that is more expensive and heavier.
Steel tubing can be easily bent on a wooden deck using blocks screwed into the deck to hold one end.
My econoline gets 17 mpg on the road I can pull a 4 wheel 3000 pound trailer and get 13.
Noah Webster, 1787
