Old 02-28-2013, 12:35 PM   #69 (permalink)
freebeard
Your modification looks well done. For the back consider the open tapered box. Reference materials at:
Effect of rear body taper on a simple body
http://bioage.typepad.com/greencarco...on-Project.pdf
Fuel Savings by Means of Flaps Attached to the Base of a Trailer: Field Test Results
Simpler construction than a boattail and you add 1/4 the vehicle's width or less in length.
