Originally Posted by ebacherville
2250 to do 55mph just seems like a waste of sucked in air.. if i can lower that to 1750 thats, 500 rpm. ... to go with 155-80-15's or those low rolling resistance 185-70-14's from the insight....
The insight tire is a 9.4% difference over stock and will give you 2057 rpm at 55mph. You of course will need to check for clearances lock to lock and under load before increasing the radius and/ or lowering
Specification Sidewall Radius Diameter Circumference Revs Mile Difference
175/70-13-----4.8in---11.3in ----22.6in -----71.1in------891--------0.0%
155/80-15---- 4.9in---12.4in-----24.8in----- 77.8in------814---------9.4%
Did I get my numbers right?
In order to get close to 1750 you will need a 195/80-16 (24% difference) Bridgestone Ecopia EP-02 (Rav4-EV tire) which inflates to 44lbs is big and $125 per corner .
as best I can figure...
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
175/70-13------4.8in----11.3in---22.6in------71.1in--------891--------0.0%
195/80-16------6.1in----14.1in---28.3in------88.9in--------713--------24.9%
