Old 03-01-2013, 01:15 PM   #46 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.93 mpg (US)
Originally Posted by SilveradoMike View Post
On hill climbing. Should I be staying in high gear or down shifting to compensate? Ie 55 mph on flat ground is about 1800rpm in 5th gear at ~15% throttle input. On a hill of decent grade or distance maintaining same throttle input speed falls off and rpm to below 1000rpm pretty quick. Should I down shift or add more throttle? Im slightly confused on this.
Here's a thread on climbing hills: http://ecomodder.com/forum/showthrea...ear-23957.html
You will need to experiment and find out what works best for your truck. Ultragauge / Scangauge is your friend when doing this.
