Old 03-01-2013, 01:34 PM   #18 (permalink)
jamesqf
Originally Posted by Diesel_Dave View Post
The main issue is this:
exhaust turbine=expensive
alternator belt= cheap
Wouldn't even say that's the main issue. The main issue is that for anything other than a hybrid, it's going to generate way more electric power than the car can use. A typical alternator might put out a maximum of around half a kW, but only a small fraction of that most of the time. Even with lights on, a car might only use a couple of hundred watts, if that.
