Old 03-01-2013, 04:51 PM   #2 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
If your grille block affects your final coolant temp, then you've blocked off too much grille. The grille block should make the engine warm up faster, but not affect the final temp.
Your thermostat should control the final coolant temp by regulating the flow rate to the radiator. If your grill block has affected the final coolant temp, that means the thermostat is full open and has lost the ability to prevent overheating.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
