Old 03-01-2013, 05:38 PM   #3 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Usually any line that has a high vacuum at idle is good. As long as your show a vacuum at cruise that goes to zero at full throttle you probably can use the gauge as it is just a relative indicator of engine load.
The power brake line is a good source but I usually refrain from cutting into that line in the interest of brake reliability.
Look for a line that goes into the intake manifold some place rather than into the air body.
Noah Webster, 1787
