The texas weather killed my grill block. My car was getting too hot for the grill block (even with the large holes in it). After I burned up my radiator fan control switch and had to replace it, I removed the grill block. I am currently working on an idea to make a grill block that stays open when the car is moving slowly and closes at higher speeds.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
