Thanks for the info, will work on the ideas you suggested, probably go with the shorter style at a bit steeper angle, I wonder if i took a sheet of plastic and attached it to the roof and held down the back edge with some struts mounted on the back of the cab, have to ruminate on it for a bit, and check supplies but seems intuitive once you think about it.with the half cover, really 4 ft on a 6 ft bed, there is a definite improvement in performance at speed, I have the last 5 or 6 inches of the cover hanging into free air past the tailgate. matched my average MPG despite an hour of idling to keep warm at work, so all good so far, almost seems crazy not to have one,
