Old 03-02-2013, 07:46 AM   #7 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Originally Posted by radioranger View Post
He's onto something there but how about a grille block made of screen that doent restrict the flow at lower speed but as speeds increase less increase in flow and more will bypass screen because of resistance, In other better words only so much air will go through the screen no matter how fast you go , but is sized so that at idle you still get lots of air,
Good idea but I wouldn't know where to start to make that work, nor do I have a way of testing to see how much air is flowing through the screen. Also I don't know how that would be adjustable for higher heat situations to allow more flow through... Say at 25mph the fabric stops pulling in additional air; Well that isn't going to change, but what if it is 100F+ outside and you need more air traveling through at speeds above 25mph. The only option at that point would be to remove it or cut holes in it.
Definitely a great idea for colder climates.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
