Old 03-02-2013, 01:08 PM   #22 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I want to pick your brain about this, oil pan. I know what I am going to ask is a bit off this topic.
So by increasing boost you get lower exhaust temps? You mentioned in another thread that you got something like 3 psi at 60 mph and that gives you several hundred degrees less exhaust manifold temps? How does that work. Besides measuring it do you have a theory about it?
If you really want to do something with all the heat going out the exhaust on a typical vehicle get a diesel and put a turbocharger or 2 on it.
Before I turboed I saw EGTs in the 1000'F to 1100'F all the time, now they rarely go above 800'F and normally stay between 400'F and 600'F.
These are all preturbine temperatures too.
Noah Webster, 1787
