Old 03-03-2013, 10:33 PM   #4 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
You will see a better result from improving aerodynamics, I ended up removing my WAI because the engine was retarding the timings when I had to stop (It has been in the 80's where I live)
I did an upper grill block and fixed my panel gaps to compensate for any FE loss.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
