Old 03-04-2013, 08:01 AM   #2 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Few years ago I was driving VW Scirocco MKII, and I've noticed that I don't have a clutch anymore. It turned out later that the shaft that was disengaging clutch went through the bearing. Anyway I was like 300km from home so I continued driving. The only problem was a full stop situation, because I needed to use starter with first gear engaged. After that I was driving without any trouble shifting gears up and down without clutch.
It's not so hard to so if you'll listen to the engine and match engine speed to the gearbox speed at the given gear. So I don't think that clutchless setup for EV conversion will be a problem.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
