The best way is use both voltage and AH counter. Just make sure that 10.5v (under load) is considered "dead" when using a volt meter.
I had a PakTrakr to monitor my lead acid pack and while it had a built in State of Charge meter, I usually used Voltage and made a cheat sheet of different SoC and their corresponding voltages.
