Aero is maybe the best thing to do... but diesel is a good choice too, if you want to get to the best.
In clear, don't spend money on your gasoline engine, spend that money on the body, now if with the body isn't enough for you, you can change your engine to a diesel one, but spend money on a gasoline engine is maybe the money worst spent.
Intake and exhaust will help, because oem engine isn't on the limit, but with closer you get to limit you get close to the detonation ...that is a bad dude haha.
