Old 06-18-2008, 01:12 PM   #209 (permalink)
ebacherville
Veggiedynamics
Volt12 - '12 Chevy Volt base
Originally Posted by 1GCRXHF View Post
You said you have the HF tranny, but are turning 2250 at 55?? My HF turns 2250ish in third gear at 60, 55 mph isn't really moving fast enough for 5th to be a player (I think something like 1500), unless the terrain is flat. I can get more mph/rpm/gear readings for you if you want, but I suspect your transmission or final drive is not the original HF running gear.
see thats what i was thinking also but some one said they had a first gen HF and my rpms seemed to be correct .. Maybe I got a CA or high altitude tranny?
Yeah RPM per speed would really help..
