Old 03-05-2013, 02:48 PM   #8 (permalink)
jayliu1984
Sorry guys I guess I didn't give enough info, but here are the things I checked/done in bullet form:
- auto trans and yes I was coasting in gear
- tires are pumped 5-6 PSI above rated pressure (38psi)
- outside temp is about 2-5 C
- communte is 6km, and 9 possible red lights/stop sighs
- check brake by drove without breaking for a while and the rotor is cold so it is not dragging
- not sure how to check if E-brake is dragging
- not sure how to check alignment, the car has 50k KM on it and no tire change
- just switched to synthetic oil so far didn't obvserve any difference
- anchor in the trunk???? what???
- the front wheel is quite difficult to turn when I jack the car up, but let's assume brake is not dragging, what else could be the cause?
However, I must add, if I put the car in neutual physically, it will coast farrrrrrrrrrrrr.....
