Old 03-05-2013, 03:50 PM   #56 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
Could you please show your math? I would like to understand how you arrived at 38% of the original power output where the Prius is alot more. I can be a little slow, if a picture shows the cross you mention well please show it if possible.
We are working along the same path of only adjusting a fixed gear intake cam, and on a similar engine (mine just has two more cylinders).
Do you have access to engine building software that can predict engine output based on varying cam timing and/or compression? That is what we really need here before we start cutting, grinding and moving gears.
Good design is simple. Getting there isn't.
The Following User Says Thank You to beatr911 For This Useful Post:
renault_megane_dci (03-05-2013)
