Every Honda with an auto I have ever driven lets you go into neutral without pushing in the button on the shifter. Bump it forward into neutral, then bump it back for drive. There is a lockout in the shifter so it won't go past neutral into reverse unless you push in the button on the shifter, so as long as you keep your finger off it you should be fine.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
