Still getting hesitation.definitely not distributor. Rpms roughly low before running it.but after its warmed up.i know it sounds wierd.but what has gotten a tad bit worse is the idle.not sure if thats related to hesitation and slight jerking.but rpms r usually at 1k and when neutral. Rise and fall rise and fall above 1k.so my guess is a vacuum leak sumwhere. i did get a new gasket for iacv and im going to make sure the bottom of pcv valve is in there tight.also check the tightness of timing belt.
