Old 03-07-2013, 05:07 AM   #19 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
If I am understanding you correctly... This is the super simple solution I have come up with. Just do the exact same thing that I have going on, but cut out a hole where your IC is and put some ducting between the hole and your IC. This way you will have constant flow to your IC and everything else will open and close depending on your driving speed. I have made up a few pics to demonstrate what I'm talking about.
Hope this helps.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
