Originally Posted by MetroMPG
coming up with a good fastening method can be the tricky part, especially if you want to be able to easily remove the parts (even trickier if you want to be able to remove them without using tools).
Metro , 3M/Scotch makes dual lock fasteners that may work for you. RF9730CH
They are similar to velcro but both sides have the plastic hooks. I've used them with great success. Maybe worth a look.
