Originally Posted by stargazerf3a
I get the signal from abs sensor and after 60 mph or 100 kph it gives rubbish information i did set the delay to 1ms but it does not solve my problem , i'll try your method although i would like to wait until you reach higher speeds...
Do you know what kind of sensor it is?
If you can get the parts free like I did it is worth a shot. Unfortunately if I go faster than about 60mph my FE goes to shizzle.... Maybe today on the 70PSL downhill I'll try to give it a bump up to 70ish and see what happens.
