Old 03-07-2013, 03:54 PM   #5 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Originally Posted by AndrzejM View Post
You can always glue a magnet to the main shaft and some kind of reed switch close enough to get pulses. You can use bicycle speed sensor even. It's hermetic, reliable and cheap
You can always use a simple diode and capacitor to filter signal. Low power diode anode to VSS sensor and 4.7uF 30V paralel to MPGuino. That should filter all the noise.
I'm not sure noise was my issue I believe it was switch bounce. The cap between VSS and ground helps to dampen switch bounce so the MPGuino only sees one edge on each pulse.
Project Avalon: E bike build
