first full tank with the escort and 38.8 mpg despite lots of idle time at work keeping warm so very happy with results, have a bad front wheel bearing i think though ,car seems noisier on turns, and isnt coasting as far. always something, my boat which really wasnt fogged properly a 3 litre chevy motor, started right up after a few pumps and ran smooth as a kitten after warm up , i had put a good 8 ounces of the tcw into about 15 gallons if fuel in the fall so probably helped it a lot since the motor was prone to sticking valves already . and due for replacing , keeps getting water in oil , as last owner never winterized it before i got it . seems to run fine though ,
