Old 03-07-2013, 10:06 PM   #13 (permalink)
Shortie771
Eco Sol
Shortie771's Avatar
Well I have found my solution in the form of a grill block that opens itself at low speed and as you increase speeds it closes. Check out my other thread. It may be able to solve your problem. Also, that thread is still pretty active, not dead like this one
http://ecomodder.com/forum/showthrea...ock-25096.html
Hope that helps.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
