Old 03-08-2013, 06:25 AM   #9 (permalink)
stargazerf3a
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
Originally Posted by AndrzejM View Post
It shouldn't be like that, with MPGuino going nuts over bumps. Check VSS cables, from the sensor to the dashboard and MPGuino. You've mentioned before that you gest VSS signal from ABS sensor, right? So you should check ABS cables then. But I don't think that plugging into ABS signal is a good idea. You can get some false signals and that can mess up your safety. It's better to fabricate VSS sensor by gluing a magnet to the drive shaft than mess up with ABS. IMHO .
No vss sensor and cables exist on my car except abs sensors and speed information travels from abs computer through the multiplex network to the whole car , i don't think it is practical to intercept that although i've tried to. Yesterday i've used abs twice due to the heavy raining and it worked perfectly as always. Though my intention is to either put a speed sensor to the gearbox from and older clio2 version of fabricate a sensor as you said but that would be extremely difficult due to the fact that drive shafts are very small and totally exposed to the elements (a belly pan could help a lot)
