Originally Posted by AndrzejM
If you have access to oscilloscope you may see what's the issue there. But if switch is bouncing that may cause ECU to work incorrectly. Maybe you should take a closer look at your VSS switch.
It is just a simple reed switch. I don't think the ECU is as sensitive to SB as the MPGuino.
