Originally Posted by AndrzejM
If you have access to oscilloscope you may see what's the issue there. But if switch is bouncing that may cause ECU to work incorrectly. Maybe you should take a closer look at your VSS switch.
Maybe mine is too cause abs sometimes feels like it locks the wheels a little when i am on a bumpy spot but that is just a reading from my butt-o-meter
I'll Try junk yard tomorrow that is a day off
ecomodding day
