Old 03-08-2013, 05:49 PM   #89 (permalink)
IamIan
IamIan's Avatar
Originally Posted by Old Mechanic View Post
If you can get the overall powertrain efficiency high enough, then you can use P&G techniques while maintaining a constant speed, even at freeway speeds. This is the crucial factor which can not be done electrically.
While I'll agree with many potential benefits of a HH ... I will disagree with the part above indicated in bold.
The Following User Says Thank You to IamIan For This Useful Post:
NeilBlanchard (03-08-2013)
