Old 03-09-2013, 07:02 PM   #1 (permalink)
Desmondghostrider
Need help installing mpguino on 95 tracker
Hey guys
I have a 2 door 4x4 soft top 16valve 1995 geo tracker
Im trying to install a mpguino.
Ive connected power and negative.
For the vss I connected to a yellow and silver wire I was told is the vss.
For the injector I connected it to a blue wire coming off the first fuel injector. Theres one per cyl so Im not sure if this is correct.
The mpguino came programed for a 94 auto geo metro but I decide to put it in the tracker instead. When installing it I accidentally pressed the buttons and messed up the settings that it came with.
Its reading that its gettig 999 mpg.
Anyone have any ideas as to if its connected correctly and what each of the settig is set on?
Thanks!
