Old 03-10-2013, 09:07 PM   #276 (permalink)
low&slow
low&slow's Avatar
l&s' Jag - '00 Jaguar S-Type SE
90 day: 25.86 mpg (US)
l&s' Vision - '82 Yamaha Vision XZ550RJ
90 day: 59.92 mpg (US)
L&S' Greenaero Ninja 250 - '99 Kawasaki Ninja EX250F Ninja 250R
90 day: 97.24 mpg (US)
SilverAero Ninja 250 - '04 Kawasaki EX250 Ninja
90 day: 88.24 mpg (US)
Hi all, I haven't posted in a while and thought I should report in.
After a disappointing performance in the 2012 Las Vegas to Barstow Vetter Challenge I knew I needed to improve my streamlined Ninja 250 to return to its previous good finishes ( 2nd overall, 1st gasoline -powered @ Mid Ohio Challenge, 3rd best @ 2012 Carmel Challenge) .
I decided to buy a Vetter fiberglass nosepiece as side by side testing with Alan Smith showed its superior performance . So I removed my Coroplast over sheetmetal framework nose and began by installing a plywood bulhead to mount the 2 fiberglass nose halves on. I cut the wheel slot, glassed the halves together and mounted the nose onto the bulkhead with 3 screws. I then make the framework to mount coroplast sides and windscreen. I've been back on the road the past 2 weeks.
I still need to do some more finish work such as sealing the plywoood bulhead and adding ducting but I wanted to see how the new nose felt and performed. I started using it to run errands to ensure it was strongly attached and that the turning clearance was OK. Engine temps are good although the weather has been cool. The bike is quieter through the air and I'm able to hold top gear longer and at smaller throttle openings than before. FOr lots of pictures of the construction check out Craig Vetter's website at Craig Vetter, designer and inventor of the Windjammer fairing,Triumph Hurricane Motorcycle and fuel economy motorcycles , its in Chapter 62
Alan just got back from Phoenix with his "new" ( 2004 model ) Ninja 250 and wanted to do a baseline test on our 100 mile test loop. So we decided to ride this morning. Alan's friend Ken joined us with his new Honda CF250. We enjoyed the ride through the backroads between Livermore and Patterson and has excellente Mexican food for lunch. We rode back to our starting point gas station and refilled our bikes: Alan: 77 mpg, Ken 83 mpg, Vic 100 mpg. The weather was cool with some wind. A good start for this current version.
Next, I need to finish off the front end and then remake my tailsection. Still lots to do before the Carmel Vetter Challenge in May but I'm looking forward to it.
all the best , Vic
The Following 2 Users Say Thank You to low&slow For This Useful Post:
HHOTDI (03-10-2013), renault_megane_dci (03-11-2013)
