Old 03-11-2013, 08:16 AM   #6 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
The VSS wire is a yellow wire A7 and injector 1 is a red wire B11. Both can be found on the two connectors going to the computer under the dash.
click =>
Also... Check the following thread if you get the dreaded switch bounce at freeway speeds.
http://ecomodder.com/forum/showthrea...ino-25144.html
Project Avalon: E bike build
