Thread: The 13mpg beast
Old 06-18-2008, 06:58 PM   #14 (permalink)
zjrog
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
And saving fuel CAN be fun. Just remember that you don't NEED to be in a hurry all the time. Then just adjust how you use the accelerator and brake. If I can get better than 20 from my brick, and DPoV can break 25 with his, we ought to be able to get a couple MPG better from yours, though the V8 will make it a little tougher.
I added some air for less rolling resistance. How much is up to you. When mine got too rough to drive comfortably I backed down some. If you aren't already using synthetic lubricants, now is a good time to switch. Might not help much, but they are better for the equipment.
Change the Tcase and adjust the speedo. I'd imagine you might be geting a little better mileage than you hink. Superlift I think makes a nice adjuster that isn't too expensive. Friend of mine with a TJ and 6" lift and 35s brought his speedo back to accuarate. Well, not certified accurate...
Originally Posted by Red View Post
Welcome to the fun.
Nice looking ZJ, I'm with rog, swap to a 242 or a 231 for MPG gains and having a "real" t-case :P Is that 13 mpg speedo corrected for the tires?
When it comes to Heroes, RENEGADES are mine!
