Hi Greg!
Sounds fine, that you use this controller such a long time!
Another thing I thought about, has anyone made something like an EMC test? Here in Austria, all components has to be EMC tested, or at least we should be absolutely sure, that nothing happens
I ask that, because the filtering isn't done very well, because it's just the capacitors which filters the pwm on the high voltage side. Has anyone problems?
