Old 03-11-2013, 03:00 PM   #2 (permalink)
nateshuntsvegas
This is great, this is exactly what I have been thinking of making for a long time. I have a 2000 Nissan frontier and its a 4 cylinder so not much power, also even so called light weight fiberglass campers are upwards of 2000lbs. Do you mind if I asked a few more details on the construction process? Did you use stringers or anything else to reinforce the foam or is it just fiberglass and foam? How many layers of fiberglass did you do inside and out? How much fiberglass and resin did this project take? Do you have any video of the process? Do you have more pictures of this project? I saw more on your other post but had more to do about aerodynamics than actual construction.
TIA
Nate
