Tire choice can make a big difference, go with skinny 15 inchers if you can find some , also have you removed the roof rack yet, if your 0 2 sensor is old can make a huge diference, they ae pretty cheap on ebay now, of course run synthetic oil 5w 30 I guess would be your choice, I have a 5 speed 98 with the stock 2.0 and runs 40 + mpg all summer, your motor is better though, smoother. change the nti freeze often , they lose head gaskets easy to corrosion .
