Old 03-11-2013, 10:37 PM   #9 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Right, that 6.6kWh would let a 2013 Leaf drive at least 23 miles, which is the same as an average car goes on a gallon of gasoline. So that means it takes just as much electricity to drive a gasoline car as it does an EV.
That 6.6 kW-h was after accounting for all of the incurred losses (waste heat, friction, etc). Can you say the same thing about the fuel that would have been burned to generate the electricity used to charge the EV? How much would that have been? And how do you address the article mentioning that it takes almost twice as much carbon generation to build a Li-ion battery, as opposed to building an entire conventional gasoline car?
And *none* of the other carbon in the gasoline, or in the natural gas, etc. used to get the gasoline would be released into the atmosphere.
That last question of mine is still relevant.
