Old 03-12-2013, 10:07 AM   #99 (permalink)
kach22i
I followed the tub link to here:
United States Panel Range
I still like Monopan better as the skin is the same plastic material as the core, plus a layer of fiberglass.
The Trev is a lot of expandable foam over a honeycomb tub, right? I like that approach because the foam offers energy absorption with light weight, at least until the foam absorbs moisture out of the air, then it could gain a few pounds.
I've been experimenting with Polymetal. I've run it through a sheet metal roller/brake/shear to assess it for the final build of a boattail.
Followed the link to here:
http://nudo.com/Spec-Sheet/Default.aspx
I cannot get any of the PDF's to open.
