Spitfire owner says hello
Hello,
I have been lurking here for a while and have finally made some modifications to my car. I commute with two cars, a 1968 Triumph Spitfire when it is not raining (most of the time) and a 2002 Jeep Liberty when it is.
So far I have added an Engine Off/Start switch to the Spitfire and have fixed a fuel leak I had. I have a vacuum gauge in it but the readings seem quite low. I think I need to move the point at which the gauge senses the vacuum.
It is a carb engine so I can't use a ScanGauge or Ultragauge, but I am acquiring the components to build an MGDuino for it. I have the Arduino board, and a fuel flow sensor from a boat (actually 2) next I need a speed sensor and an LCD panel.
I have started doing some of the hypermiling techniques too. I am still on my first tank since starting all this stuff, so I don't know how well I am doing. I have had the car since I was 14, and I am 48 now. The best MPG I regularly got from it was about 24 MPG, so anything better than that and I know I am doing well.
Best Regards,
Kirk
