Originally Posted by turbothrush
I know what you mean about heavy campers.
Don't have a video but questions are no problem. Camper is still not done but I still work on it when I have time.
There is no stringers . I made all the panels on a large flat table made from used hollow core doors joined with biscuits(no glue). The table is important since all the panels index off the table if you want a camber in the panels or if you just want a flat panel. I used formular 300 foam from Home Depot which is 30lbs/sq inch crush strength.This seems to be enough with 2 layers of 6 oz cloth when weave is filled the microbaloons on the outside. Inside just 2 layers of cloth.
I used duct tape for clamps and Gorilla Glue for gluing the panels together.
Attachment 12673
I let in hardwood blocks into the foam before glassing for attachments points for jacks , ladder , table ,tiedowns etc.
I will have used about 10 gal of epoxy and about 1600 sq. ft of fiberglass cloth(400 sq ft of panel area x 4 layers total ) and probably 3 or 4 gallons of microballons and 1 gal of cabosil for filler and gap filling glue.
Bare shell comes in at under 400 lbs. with windows
Fun project but big in more ways than one.
Do you think it will be strong enough to have a walk-on roof?
What are your material cost so far?
How many hours do you think you have into the project so far?
Thanks for all the answers.
Nate
