Old 03-13-2013, 02:37 AM   #9 (permalink)
S-cort
The Wagon - '95 Ford Escort Wagon LX
90 day: 28.22 mpg (US)
The Green Ox - '93 Toyota Pickup DX
MADMIKE- Thanks for the AT tips. My car does experience a hard 1-2 shift. I will have to pull out the PRV valve and check it out. When I bought the car the AT was slipping from a standstill into 1st. I changed AT fluid and filter and added a Lucas Trans additive. The slipping went away entirely. The other issue I had was the AT slipping while climbing a steep grade causing the trans to overheat. I don't normally drive steep grades, but the trans cooler would sure help when I do.
I have read about adjusting toe-in to improve mileage. Will adjusting camber to 0 also help mileage or just tire wear?
