Old 03-14-2013, 10:33 AM   #4 (permalink)
razor02097
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
Originally Posted by Accented View Post
Have you tried your LBS (local bike shop, I'm used to cycling forums)? Often these shocks are rebuild-able, hence the cost, even if it cannot be rebuilt, they may have a good take-off from another customer's upgrade.
Since this site is all about economy, a rear shock is a huge energy waster, if you are not riding off-road you could convert to a rigid rear end. A piece of tubing with 6.5" holes would accomplish this very inexpensively, adding a heim joint would allow ride height adjustment, but would be more costly and take fabrication. This will at least get you back on the road while your search for a new shock continues.
All the reason to invest in a better shock. If the OP is noticing the bike bouncing around I doubt the OP wants all the shocks being transferred to the spine instead.
Project Avalon: E bike build
