My main goal is fuel efficiency which seems to be yours as well, WD40. I assume if you're considering refurbishing your original injectors, you must not be totally satisfied with the OsideTiger injectors because of their aforementioned difficulty to keep them efficient in lean burn. If this is true, I may just have my stock injectors refurbed as well. You're pretty much about to sway my choice one way or another, so I appreciate the added feedback.
